ar2
Wsparcie
Członek Załogi
HD Squad
LED TV 46” 55” 65”
Display
Ultra Clear Panel Yes
Video
Resolution 1920 x 1080
Picture Engine 3D HyperReal Engine
Wide Color Enhancer Plus Yes
Auto Motion Plus 120/240Hz Yes (240Hz)
Audio
Dolby Dolby Digital Plus, Dolby Pulse
SRS SRS TheaterSound
dts 2.0 + Digital Out Yes
Sound Output (RMS) 10W x 2 15W x 2 15W x 2
Speaker Type Down Firing
Woofer Yes
Feature
Samsung 3D Yes
Anynet+ (HDMI-CEC) Yes
Auto Channel Search Yes
Auto Power Off Yes
Auto Volume Leveler Yes
BD Wise Yes
Caption (Subtitle) Yes
Clock & On/Off Timer Yes
AllShare (Powerd by DLNA) Yes
EPG No
Game Mode Yes
Internet@TV Yes
Skype on Samsung TV Yes
OSD Language English, French, Spanish
Picture-In-Picture 1 Tuner PIP
Sleep Timer Yes
USB Movie
WiFi Adaptor Support Yes
Extended PVR No
Still Picture No
V-Chip Yes
Touch Remote Control Support Yes
Wireless Remote Control Yes
System
DTV Reception (ATSC) ATSC & Clear QAM
DTV Tuner Built-in Yes
OCAP / ACAP No
Input & Output
Audio Out (Mini Jack) 1
Component In (Y/Pb/Pr) 1
Composite In (AV) 1
Digital Audio Out (Optical) 1
DVI Audio In (Mini Jack) 1 (Common use for PC Audio In)
Ethernet (LAN) 1
Headphone No
HDMI 4 (v1.4 with 3D, Audio Return Channel)
PC Audio In (Mini Jack) 1
PC In (D-sub) 1
RF In 1
RS232C (AV CONTROL) 1
USB 2
Design
Front Color Silver
Light Effect (Deco) Yes
Stand Type 4 Legs
Swivel (Left/Right) Yes
Power
Eco Mark EnergyStar 4.0
Eco Sensor Yes
Power Supply AC110-120V 60Hz
Opereation Power Consumption 120W 140W TBD
Power Consumption (Stand-by) <0.1W
Dimension
Package Size (WxHxD) 1360 x 810 x 150 1585 x 898 x 200 1360 x 810 x 150
Set Size (WxHxD) with Stand 1090.8 x 723.8 x 303 1282 x 832.7 x 303 1090.8 x 723.8 x 303
Set Size (WxHxD) without Stand 1090.8 x 662.8 x 23.9 1282 x 772 x 23.9 1090.8 x 662.8 x 23.9
Weight
Package Weight 22.9 30 22.9
Set Weight with Stand 19.2 24.2 19.2
Set Weight without Stand 17 22 17
Accessory
3D Glasses No
ANT- Cable No
Batteries Yes
Instruction Book Yes
Power Cable No
Recharger (Remote Controller) No
Remote Controller Model TM1080
Slim Gender Cable 1 Component, 1 Composite Audio, 1 Composite
Ultra Slim Wall Mount Support Yes
Floor Stand Support Yes
Vesa Wall Mount Support Yes (46-55" : 400 x 400) Yes (46-55" : 400 x 400) Yes (60-65" : 600 x 400)​
Premium Remote Controller Metal
michalmichalmic
Sa tez inne zdjecia podswietlenia np. to jednoznacznie pozytywne pokazujace dobra czern na tym tv. Jednak rozne zdjecia pokazujace to podswietlenie powoduja doze niepewnosci i mieszane odczucia. Po raz kolejny nie bedzie to lcd bez wad bo taki lcd nigdy nie zostanie wyprodukawany seryjnie. Ach ta technologia lcd.
    273,8 KB · Wyś: 508
michalmichalmic
Pojawil sie C8000 na polskiej stronie Samsunga. Wersje 40 i 46 cali a roznica z c7000 to podswietlenie strefowe w C8000 bo tak wykazalo porownanie ich na tej stronie. Widzial juz ktos gdzies w jakims sklepie?
Wazne. Tam jest nowe oprogramowanie dla serii C7000 i osobno dla C8000 wiec jak ktos kupi to zanim na cos zacznie narzekac to niech wgra nowe najpierw.
michalmichalmic
Na stonie jednego sklepu internetowego pojawily si C8000. Dzwonilem i beda dopiero za 2 do 3 tygodni do kupienia, ale to juz jakies info bo lepsze takie niz zadne.
A ceny to;
46C8000 za 7850zl
55C8000 za ok 10700zl
o 65C8000 nic nie wiadomo a ciekawy jestem za ile pewnie prawie 20tys?
46C7000 za 7100zł
55C7000 za 9250zł
Fajnie by bylo znac odpowiec na pytanie czy warto doplacac do C8000 dla tego czegos co zwa precision dimming?
MAdam
Na tych zdjeciach C8000 co wrzucił jtd to raczej fatal dimming, ale mam po cichu nadzieję, że tą wystawę obługiwały i ustawiały tv nie znające się na ustawieniach ładne laseczki ;) . A poważniejto wygląda to tam fatalnie, prawie jak foto iluzja :(
RHJG
Witam,masz racje kolego MAdam te zdjecia z wystawy sa tak jak napisales.Widzialem ten ten TV C 8000 wczoraj w Berlinie,mialem przy sobie pena i puscilem plansze testowe(tak sie sprawdza na szybko podswietlenie,matryce i inne duperele)Powiem krotko jest b.dobrze tak jak myslalem potwierdzily sie greckie, wloskie i inne testy.Nic tylko zbierac kase-moim zdaniem warto.pozdr.
michalmichalmic
Zdjecia od jtd pochodza z forum avsforum i sa zrobione na jakims sklepie przez jakiegos amatora z tego forum. Z prawej jest B8500 z local dimming (widac efekt halo) z lewej C8000 z precision dimming. Tyle ze dla C8000 to juz trzy nowe firmware sa na rynek Usa wiec sa nieaktualne a poza tym to na sklepie sa ustawione w prezentacji sklepowej czyli 100proc podswietlenie. Autor zdjec twierdzil ze patrzac pod katem jest nowy efekt na ktory wymyslil nawet nazwe, natomiast na wprost efekt ten nie istnieje dlatego zdjecia sa pod katem. Sam pisal ze poszedl zeby znalesc slabe punkty nowego podswietlenia wiec intencje mial raczej nieciekawe robiac te zdjecia.Tyle ze dotad nikt inny tego nie potwierdza a wiele osob na tym forum juz pisalo swoja opinie po kupnie C8000. Ja tez nie chce bronic samsunga bo co mi z tego ale zdaje sobie sprawe ze technologia lcd ma swoje ograniczenia.
Sklep do ktorego dzwonilem twierdzi ze ceny na 46C8000 moga byc nawet nizsze od podanych teraz czyli 7800zl za 46 cali wiec pewnie go kupie. Jak bede go mial pierwszy to zdam relacje co i jak choc sprawa z tunerm sat jest raczej przesadzona i bedzie ale w wersji na rynek np. Niemiecki C8790 a na Austrie C8780 juz bez tunera no cos dziwactwa i tyle.
Google Käännä
Andrew150
Podświetlanie
Bardzo proszę kogoś z bardziej doświadczonych userów o wyjaśnienie laikowi na czym polega strefowe (lokalne) podświetlanie, czyli jak zrozumiałem precision dimming. Przymierzam się też do tego modelu i chciałbym być przekonany, że jest różnica między 7000 i 8000.
Z góry wielkie dzięki.
Pabloos
46 c8000
Przyjechal do mnie dzis rano,pierwsze co to w porownaniu z SonyW4500 i klocowata Toshiba SV istny diamencik.Dzis wieczorem "Moon" i "District9" a jutro dokladniejsza kalibracja!
arturos1970
no to pochwal sie,jakie wrazenia?ile dales?no i gdzie kupiles?sam jestem zainteresowany takim tv,dzis bylo bezwacie MM,stal samsung40c7000 za 4900,niestety byla to ostatnia sztuka i odrazu zeszla,byly tez 46calowe,ale tez wszystkie zeszly.:(
michalmichalmic
Ja na bezvat nie pojechalem bo w MM w moim w woj. Ślaskim cena za 46C7000 to 9tyś zl przed bezvatem to zadna promocja po odjeciu 18,03 proc a za 55C7000 13tys poza tym C8000 jeszcze nie byla a chocby byl to za 10 tys lub wiecej za 46 cale.
W zadowolenie.pl jest na razie tylko 40 cale C8000 ale az za 6,4tys.
Pabloos
Telewizor kupilem za 2tys.funtow w sklepie internetowym,ale mieszkam w Angli.Narazie bawie sie ustawieniami obrazu ale juz mam pozytywne zdanie o tym TV.Film Moon gdzie jest duzo odcieni szarosci i ciemnych kolorow prezentowal sie swietnie.Lokalne wygaszanie diod naprawde dziala(chodz gdy sie podejdzie do telewizora to pod kontem widac efekt poswiaty)Clouding wystepuje tylko w jednym rogu ale jest widoczny na ustawieniach dynamicznych.Wieczorem zrobie zdiecia z ciemnymi scenami i postaram sie je wkleic jeszcze dzis.Jezeli chodzi o sam tv i pilot to jakosc wykonania i materialy sa swietne,jedynie dzwiek jest plaski jak ten tv!.Dzis mam zamiar wgrac najnowszy soft i zobaczymy jak to wszystko bedzie smigac.Pozdro
    840,5 KB · Wyś: 1594
Pabloos
Jeszcze jedna fotka
Zdiecia kiepskiej jakosci ale robione telefonem!
    663 KB · Wyś: 514
jtd
ile to jest cali ? czekamy na fotki z wieczora, wylacz kompletnie swiatlo w pokoju, pusc film z ciemnymi scenami i zrob kilka fotek ale bez flasha ! :)
michalmichalmic
Poogladaj troche 3d trailers ze stron(linki ponizej). Albo przez usb z pena czy dysku albo moze z komputera przeslane na tv. Pisza tam ze sa filmy 3d side by side ale rowniez podzialka jest u gory i na dole wiec to trzeba odpowiednio wlaczyc na tv. Oczywiscie jak masz okulary 3d. Napisz jakie wrazenia i wgraj nowy soft. Czekamy na nocne fotki bez flash. Masz wersje z tunerem sat bo wersja na POL C8000 jest raczej bez i trzebaby kupic niemiecka C8790 bo ona ma.
www.biohemmet.se
http://forums.nvidia.com/index.php?showtopic=166605
avatar german 3d trailer - 3D Vision Blog
