Jak w VT60 sprawdzić ilość godzin pracy ?
Wchodzę w menu serwisowe zgodnie z instrukcją:
1)Press and hold the "VOL -" button ON THE PLASMA TV.
Do not release the "VOL-" button just yet.
2)While holding the "VOL-" button on the TV set itself, now press the "INFO" button on the remote control 3 times
"Start Adjustment Menu" message will be displayed followed by the Service Menu after few seconds.
You should see this as your display:
ADJUST {Picture Adjustment}
WB-ADJUST {White Balance Adjustment}
OPTION {Option Setting}
V-SUS {V-SUS Adjustment}
AGING
SRV-TOOL {Service Tool}
"1" & "2" buttons move through options
This is your first button press while in the above display:
3) Press the "2" button once to select "SRV-TOOL".
Your display will look like this:
SRV-TOOL VIVID
00 (note that this 00 is high lighted in orange. Just leave it there. Do not scroll away from this)
1,2:MAIN SELECT
9
icture MANU SELECT
OK:ENTER
4) Then press the "OK" button to access it. Note: Do not scroll. you should not highlight the OK selection on your screen. You are simply hitting the "OK" button on your remote.
5) Using the cursor keys, highlight the right side of the last item "PTCT :00.00.00.00.00" Note the "right side" of the last item is a blank box for time being.
Your movements with the remote control cursor on your remote should be five presses down and one press to the right in order to accomplish step #5
6) Then press and hold the {MUTE} button for 3 seconds.
Time and Count will be displayed in red color:
I got Time 00000:48 Count 0000020
__TIME = Hours : Minutes of operation.
COUNT = Times the Plasma was powered on.
ale w punkcie 3 po naciśnięciu "2" nie wchodzę w SRV-TOOL VIVID tylko w USB HDD....
Ktoś mnie może naprowadzić ?
AGING
SRV-TOOL VIVID
1,2:MAIN SELECT
9
OK:ENTER
