TV LCD LED Samsung 9 c9000 (46" 55") Wszystko o serii 9000 opinie testy
ar2
Wsparcie
Członek Załogi
HD Squad
LED TV 46” 55”
Panel
Ultra Clear Panel Yes
Video
Resolution 1920x1080
Picture Engine 3D HyperReal Engine
Wide Color Enhancer Plus Yes
Auto Motion Plus 120/240Hz Yes (240Hz)
Audio
Dolby Dolby Digital Plus, Dolby Pulse
SRS SRS TheaterSound
dts 2.0 + Digital Out Yes
Sound Output (RMS) 15W x 2
Speaker Type Stand Built-In
Woofer Yes
Feature
Samsung 3D Yes
Anynet+ (HDMI-CEC) Yes
Auto Channel Search Yes
Auto Power Off Yes
Auto Volume Leveler Yes
BD Wise Yes
Caption (Subtitle) Yes
Clock & On/Off Timer Yes
AllShare (Powerd by DLNA) Yes
EPG No
Game Mode Yes
Internet@TV Yes
Skype on Samsung TV No
OSD Language English/ French/ Spanish
Picture-In-Picture No
Sleep Timer Yes
USB Movie/JPEG
WiFi Adaptor Support Yes
Extended PVR No
Still Picture No
V-Chip Yes
Touch Remote Control Support Yes
Wireless Remote Control Yes
System
DTV Reception (ATSC) ATSC/Clear QAM
DTV Tuner Built-in Yes
OCAP / ACAP No
Input & Output
Audio Out (Mini Jack) 1
Component In (Y/Pb/Pr) 1
Composite In (AV) 1 (Common use for Comp Y)
Digital Audio Out (Optical) 1
DVI Audio In (Mini Jack) 1 (Common Use for PC Audio)
Ethernet (LAN) 1
Headphone No
HDMI 4
PC Audio In (Mini Jack) 1
PC In (D-sub) 1
RF In 1
RS232C (AV CONTROL) 1
USB 2
Design
Front Color Silver
Stand Type Square
Swivel (Left/Right) Yes
Power
Eco Mark Energy Star 4.0
Eco Sensor Yes
Power Supply AC110-120V 60Hz
Operation Power Consumption TBD
Power Consumption (Stand-by) <0.1W
Dimension
Package Size (WxHxD) 1236 x 887 x 396 1417 x 993 x 397
Set Size (WxHxD) with Stand 1104 x 819 x 306 1295 x 873 x 306
Set Size (WxHxD) without Stand 1104 x 674 x 8 1295 x 784 x 8
Weight
Package Weight 30.3 36.4
Set Weight with Stand 21.8 25.3
Set Weight without Stand 10.3 10.3
Accessory
3D Glasses No
ANT- Cable No
Batteries Yes
Instruction Book Yes
Power Cable Yes
Recharger (Remote Controller) Yes
Remote Controller Model TM1090(Touch Remote)
Slim Gender Cable Component ,CVBS Gender Cable
Ultra Slim Wall Mount Support No
Floor Stand Support No
Vesa Wall Mount Support No​
Premium Remote Controller Yes
wszechmogONcy
Na niemieckiej stronie producenta są już modele 40c9090, 55c9090 i 46c9090. Na innych bardziej europejskich niż Polska :) też pewnie są. Wiadomo kiedy będą u nas dostępne?
oglądałem go w sklepie kosztował 6000 $ .
Świetnie się prezentuje. Leciały trailery 3D .
Kolejek nie było. Zauważyłem nie równe podświetlenie nawet w jasnych scenach.
benk07
Wynika z tego, że ta przypadłość nierównomiernego podświetlania jest wspólną cechą C7000, C8000 i C9000.
Ja w swoim 55C7000 powoli się do tego przyzwyczajam. Gadałem Samsungiem (infolinia), gdzie człowiek powiedział mi, że jak zawezwę serwis i oni potwierdzą, że coś jest nie tak z matrycą to będzie zakwalifikowana do wymiany. Tylko pytanie, czy ta, która przyjdzie do wymiany będzie pozbawiona tej wady?
Trochę mi się nie chce z tym walczyć bo ten telewizor sprawia jednak sporo przyjemności i jestem z niego ogólnie zadowolony. Znowu ewentualna wymiana na coś innego - jakiś model z wyższych serii C Samsunga, czy inna marka - tez raczej nie wchodzi w grę. Bo i kwestia kasy, i tego, że inne wcale mi się bardziej nie podobają.
Nie ma chyba telewizorów idealnych. A nawet jak w jakimś obraz jest zbliżony do ideału to (przynajmniej w moim wypadku) nie podoba się design, czy coś innego doskwiera, np. cena ;-).
Wybór sprzętu, jak wszystkim wiadomo, jest obarczony często jakimś kompromisem. A kompromis, to często również jakiś "ból".
sprawa c 9000
Witam wszystkich ja dzisiaj tez widzialem c 9000 i powiem tak jesli chodzi o tlumy ktore niby to kiki nie widzial, to w MM w Warszawie ludzie nie mogli odejsc od tego tv poprostu byli oczarowani zreszta tak samo jak i ja :) pomimo ze jestem zwolennikiem philipsa ( na razie nie mam ani jednego ani drugiego wiec jestem obiektywny w ocenie ) to jesli chodzi o wyglad to samsung, philipsa 9705 to przewyzsza o klase.... ja na szczescie jeszcze tearz nie kupuje i nadal sie zastanawiam czy to bedzie samsung czy philips w przyszlym roku bede musial podjac decyzje i obraz tez byl calkiem niezly, a lecial jakis program z anteny i naprawde moglobyc aczkolwiek gdyby to byl sygnal cyfrowy to byloby o wiele lepiej nie mowiac o hd. Pozdrawiam .
Lolek
accu
Witam. Klasa telewizora Samsung 55"C9000 jest niepodważalna , tylko cena jednak trochę astronomiczna.
Pozdrawiam,:)
wszechmogONcy
Na niemieckiej stronie producenta jest 40" Cena 3,999,- Euro oczywiście.
Dokładny model UE40C9090.
Kiedy będzie w Polsce? Przygarnąłbym na test od kikiego.
z3
To chyba jakaś szydera jest. Mogę się założyć, że nie testowali tego TV tylko opisali wrażenia np po targach IFA. Takie okłamywanie czytelników staje się nagminne. Dlaczego tak twierdzę? Każdy szanujący się serwis jeśli ma dany produkt robi jemu zdjęcia a nie zamieszcza fotografie od producenta. Poza tym nie opisano funkcji jak np time shift. wg mnie DNO nie polecam.
accu
Witam. Nie trzeba się tak denerwować tą recenzją. Autor tej recenzji John Archer zna się na rzeczy i stara się być obiektywnym recenzentem . Trzeba neutralnie podchodzić do poszczególnych recenzji produktów .:neutral:
Pozdrawiam , :)
TomToms
Wreszcie na polskiej stornie samsung pojawiła się seria 9.
Ciekawe kiedy masowo trafi do sklepów, czekam na niego od marca kiedy to niby miał po raz pierwszy zacząć trafiać na półki ;)
Geezer
5500 GBP za Edge LED ?!?
Trzeba na głowę upaść...
Jak ktoś chce cienki TV to od stycznia 2011 będzie LG LEX8...
Full LED, 2D->3D
Full LED, 2D->3D
Witam a co to bedzie za tv i w jakich rozmiarach ? wiesz cos wiecej na ten temat? Pozdrawiam i jakbys cos wiedzial wiecej to napisz.
Lolek
RHJG
witam,a dlaczego nie jak kogos stac,a TV jest piekny i tez ma konwersje 2D na 3D itp,itd.LG LEX8,lub 9 tez bedzie podobnie kosztowal.Tak to jest z topowymi modelami...pozdr.
